Diverse ports, four service slots, up to 128 x 100GE QSFP28 ports or 64 x 100GE QSFP28 and 16 x 400GE QSFP-DD ports
Hardware-level redundancy, ensuring service continuity
Lossless Ethernet, ensuring zero packet loss during RDMA E2E communication
Telemetry-based network monitoring and automated O&M, making management simple and efficient
Highly-efficient heat dissipation and energy saving, with power consumption less than 1950 W and power conversion efficiency up to 94%
RG-S6920-4C |
Ports |
100GE/400GE ports |
Expansion Modules |
Four expansion modules, with each module supporting 32 × 100GE ports |
Expansion Slots |
Four power supply module slots Six fan module slots |
Management Port |
Switching Capacity |
25.6 Tbps |
Packet Forwarding Rate |
8000 Mpps |
802.1Q VLAN |
4094 |
RG-S6920-4C |
Dimensions |
442 mm × 735 mm × 173.6 mm, 4 RU |
About 43.5 kg (including all line cards, power supply modules, and fans) |
RG-S6920-4C |
Maximum Power Consumption |
1950 W |
AC |
Rated voltage range: 100 VAC to 240 VAC, 50 Hz to 60 Hz Maximum voltage range: 90 VAC to 264 VAC, 50 Hz to 60 Hz |
High-voltage DC |
Input voltage range: 192 VDC to 288 VDC |
RG-S6920-4C |
Operating Temperature |
0ºC to 40ºC (32ºF to 104ºF) |
Operating Humidity |
Working altitude |
Software Specifications |
RG-S6920-4C |
L2 Protocols |
L3 Protocols (IPv4) |
IPv6 Basic Protocols |
IPv6 Features |
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, manual tunnel and IPv4 over IPv6 tunnel |
Data Center Features |
PFC, ECN, and other data center features M-LAG RDMA OpenFlow 1.3 |
Visualization |
gRPC sFLOW sampling INT |
ACL |
Standard IP-based ACL、Extended MAC-based ACL、Extended IP-bsaed ACL、Expert-level ACL、ACL 80、IPv6 ACL、Ingress/Egress ACLs、ACL Logging、ACL Counter (Ingress and egress counters are supported in interface or global configuration modes)、ACL Re-marking、Global ACL、ACL-based Redirection、Displaying ACL Resources、Processing First Packet of TCP Handshake When Binding the ACL to Restrict SIP、Matching Against 5-Tuple of Pass-by VXLAN Inner IP Packets、The expert-level ACL supports matching the IP flag and DSCP fields of VXLAN inner packets |
QoS |
HA Design |
Security Features |
Management Mode |
SNMP v1/v2/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm function, temperature alarm function, and configuration rollback |
Other Protocols |
Specification |
RG-S6920-4C |
Safety |
● IEC 62368-1 ● EN 62368-1 ● EN IEC 62368-1 ● BS EN IEC 62368-1 ● UL 62368-1 ● CSA C22.2#62368-1 ● GB 4943.1 |
● EN 55032 ● EN 55035 ● EN IEC 61000-3-2 ● EN IEC 61000-3-3 ● EN 61000-3-3 ● ETSI EN 300 386 ● EN 300 386 ● ICES-003 Issue 7 ● ICES-003 Issue 6 ● ANSI C63.4-2014 ● FCC CFR Title 47, Part 15, Subpart B ● AS/NZS CISPR 32 ● CISPR 32 ● GB/T 9254.1 |
Environment |
The configuration procedure for the RG-S6920-4C switch is as follows:
● Select the switch.
● Select expansion modulesbased on business requirements.
● Select Optical Transceivers based on port requirements.
Product Model |
RG-S6920-4C |
Four expansion slots, four power supply module slots, and six fan module slots |
RG-PA1200I-F |
M2EFAN I-F |
Fan module, supporting 5+1 redundancy, hot swapping, and front-to-rear ventilation design |
Product Model |
M6900-32CQ |
32 x 100GE ports |
M6900-16CQ4QC |
16 × 100GE optical ports (QSFP28) + 4 × 400GE optical ports (QSFP-DD) |
Product Model |
400G-QDD-DR4-SM1310 |
400G-QDD-FR4-SM1310 |
400G-QDD-SR8-MM850 |
Product Model |
100G-QSFP-SR-MM850 |
100G-QSFP-iLR4-SM1310 |
100G-QSFP-LR4-SM1310 |
100G-QSFP-ER4-SM1310 |
100G-AOC-10M |
100G-AOC-5M |
Product Model |
40G-QSFP-iLR4-SM1310 |
40G-QSFP-LR4-SM1310 |
40G-QSFP-LSR-MM850 |
40G-QSFP-SR-MM850 |
40G-QSFP-LX4-SM1310 |
40G-AOC-30M |
40G-AOC-5M |
